Club G40
May 23, 2012, 06:27:24 pm *
Pages: [1]   Go Down
Author Topic: Suspension - springs, shocks, and coilovers.  (Read 1196 times)
Phil
Traders
Offline Offline
« on: February 09, 2011, 12:08:45 am »
Budget german suspension kit, 4 uprated and shortened shocks, lowered springs available in -40, 60, or 80mm. Adjustable rear spring platform for ride height adjustment, about as good as your going to get without spending more than double. 2 year warranty - £140 delivered.
4 Uprated shocks - £105 delivered.
Lowered spring kit - £70 delivered.
2 Front or rear shocks - £70 delivered.
Spax adjustable kits - coming soon
H&R cup kit, 40 or 60mm, excellent kit, much better ride quality - £445 delivered
TA technix coilovers, custom made strut requiring no strut exchange, height adjustable coilovers all round, very large drop if need be. TUV approved, good ride quality, lowered steering arm which helps reduce bump steer. £490 delivered.
Gaz adjustable coilovers, custom made from your old front struts (may be able to arrange exchange/spare struts) Bump and rebound adjustable on a 3:1 ratio, custom spring ratings to suit your needs. They come with a 2 year warranty, the rears have been chrome nickel plated, and the fronts black zinc coated. £695.
Gaz adjustable front shocks, these are standard size so fit into a normal strut and the piston has been shortened to suit a 60-90mm drop. Ride quality will improve, and they are bump and rebound top adjustable on a 3:1 ratio like the coilover units. £185 delivered.
Budget rear coilovers, very stiff, good for stopping those wide rear wheels rubbing! £120 delivered.
Super Pro polybushes, usually next day delivery -
Front lower arm set, inner and outter (both sides) - £65
Anti Roll Bar to chassis - £20
« Last Edit: February 09, 2011, 12:30:34 am by Phil » Logged
G40 loon
Offline Offline
« Reply #1 on: September 18, 2011, 06:46:43 pm »
how do i pay i'd like a 60mm budget kit  Grin
Phil
Traders
Offline Offline
« Reply #2 on: September 19, 2011, 11:27:17 pm »
Payments usually through paypal or bank transfer, give me a PM if you'd like to order a kit.
mario-g40
Offline Offline
« Reply #3 on: March 08, 2012, 09:27:16 am »
hello,phil is it possible to take just the rear coilovers from gaz from the set for 695£ possible to send to belgium?whats the price? I have kw v2 inoxline coilovers but on off the rear is gone
Pages: [1]   Go Up
Jump to:
