Classifieds
Articles
Forum
Merchandise
Home
May 23, 2012, 12:37:14 pm
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
News
Home
Help
Calendar
Login
Register
Technical
Engine and Transmission
Lambda Sensor
Pages: [
1
Go Down
« previous
next »
Author
Topic: Lambda Sensor (Read 1360 times)
GTG40
Offline
Lambda Sensor
on:
August 21, 2008, 08:53:38 pm »
Have a look at the graph the lambda is in yellow (revs: Blue)
Dosen't seem very consistant.
do you rekon its broke?
[attachment=111]
Last Edit: August 21, 2008, 08:56:56 pm by GTG40
Administrators
Online
The CV joint killer
Re: Lambda Sensor
Reply #1 on:
August 21, 2008, 09:35:39 pm »
the lambda will cycle inbetween 0-1 volt at idle that's normal. Also you need to ignore any values it gives till it up to temp which takes a few minutes, lambda probes dont work when cold so will give off daft readings.
Are all the graphs inverted? Quite confusing! I would say it appears to be ok though but your idle looks pretty rough esp since it seems to dip down to 500rpm at one point. The lambda is used on part throttle so try to get some logging done while driving the car using a range of RPM and engine loads. Obviously you need a laptop to do that!
GTG40
Offline
Re: Re: Lambda Sensor
Reply #2 on:
August 21, 2008, 10:21:09 pm »
[quote pid=3487 author=hayesey date=1219354539]the lambda will cycle inbetween 0-1 volt at idle that's normal. Also you need to ignore any values it gives till it up to temp which takes a few minutes, lambda probes dont work when cold so will give off daft readings.
Are all the graphs inverted? Quite confusing! I would say it appears to be ok though but your idle looks pretty rough esp since it seems to dip down to 500rpm at one point. The lambda is used on part throttle so try to get some logging done while driving the car using a range of RPM and engine loads. Obviously you need a laptop to do that![/quote]
Thanks for the advise i'll record some values while driving.
It runs at low rpm when cold, when i'm driving its fine, its when its ticking over. then when its warm then it ticks over alot better. i've changed the blue temp sensor (VW) but that didn't make much difference.
Last Edit: September 18, 2008, 04:15:18 pm by GTG40
Administrators
Online
The CV joint killer
Re: Re: Re: Lambda Sensor
Reply #3 on:
August 22, 2008, 08:39:45 am »
I doubt that's the lambda as it's not used by the ecu when the car is cold, it only comes into effect when it is warm.
But the best thing to do is to do some logging like you have been doing but all as many sensors as you can! Also check out the engine diagnosis guide in the FAQ section.
Pages: [
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Club G40
=> Announcements
=> General Car Chat
=> General Chat
=> Ongoing Projects
=> Meets and shows
=> Photos and videos
Technical
=> Engine and Transmission
=> Chassis & Braking
=> Electrical
=> Engine and transmission FAQ
=> Chassis FAQ
=> Electrical FAQ
=> Superchargers / G-Lader
=> Turbochargers
=> Superchargers FAQ
=> Exterior and Interior
=> Exterior and Interior FAQ
Classifieds
=> Parts for sale
=> Traders parts and services
=> Cars for sale
=> Wanted
=> Misc For Sale
=> Group Buys
Club Sponsor - PPP
=> Polo Performance Parts
Reviews
=> Company Reviews
=> Seller/Buyer Feedback
Loading...
