Club G40
May 23, 2012, 11:50:09 am *
Welcome, Guest. Please login or register.
Did you miss your activation email?
   Home   Help Calendar Login Register
Pages: [1]   Go Down
Author Topic: High idling after gt inlet  (Read 361 times)
BrettG40
Offline Offline
« on: July 24, 2010, 07:51:32 pm »
Ive fitted a gt inlet manifold this afternoon, everything is in the same place as it was before it came off, all the breathers are in the same position and now its decided to idle at about 1200? I have tried adjusting the idle screws, the isv was cleaned when i had it off so im kinda struggling, any ideas guys?
Brett.
Administrators
Offline Offline
Housewives heart throb
« Reply #1 on: July 24, 2010, 07:54:49 pm »
air leak? did you replace the gasket?
BrettG40
Offline Offline
« Reply #2 on: July 24, 2010, 08:00:36 pm »
Yeh i put a new gasket on, but how could it not be fitted correctly, surely it couldnt be that far out to cause an air leak?
Administrators
Offline Offline
« Reply #3 on: July 24, 2010, 09:13:33 pm »
i once creased the gasket in the corner and it idled about 2000
DKnight
Administrators
Offline Offline
WWW
« Reply #4 on: July 30, 2010, 12:01:27 am »
did you change the throttle cable bracket?
i did this and forgot to change the bracket and gt ones are different, so it idled high, easy mistake to make!
im 99% sure this will be your problem
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.16 | SMF © 2011, Simple Machines Valid XHTML 1.0! Valid CSS!
