Club G40
May 22, 2012, 07:03:34 pm *
Welcome, Guest. Please login or register.
Did you miss your activation email?
   Home   Help Calendar Login Register
Pages: [1]   Go Down
Author Topic: G40 Turbo bits  (Read 1205 times)
dubbeh
Offline Offline
« on: March 08, 2010, 02:25:09 pm »
MK4 Polo AEX cast exhaust manifold - I had a laser-cut flange made up to 'flip' the manifold upside down. I then used 8mm mild steel to create a flange for the T25 turbo, which was professionally TIG welded to the manifold. It's not the best looking manifold in the world but its very strong (being cast) and seals up perfetly. The manifold also gives you the option to fit different turbos from the garrett range, like the T2 or T28.
Garrett T25 turbo - The turbo is now in need of a rebuild, or replacing.
Turbo down pipe - made from mild steel. Its had several coats of VHT paint and has been heat wrapped to control under bonnet temperatures. The diameter is 2.5" directly from the turbo outlet.
GT Head,
Freshly refurbed g40 rocker cover, looks like new.
G40 ECU with chip - ECU works as it should and is fitted with a Pistop developments 250cc EPROM chip.
Brand new water pump.
Brand new timing belt.
Brand new Head bolts.
Braided turbo oil feed - This is a 'Hose Solutions' item. Very good condition (cost over £40 alone). Included are the appropriate banjo fittings for the cylinder head and turbo.
Heavy duty 16mm ID turbo oil return pipe.
Turbo coolant T-pieces, and banjo fittings.
Oil catch tank/ pipe/ filter- This is a homemade rectangle-shape tank, painted matt black. Includes the pipe for the crankcase breather and breather filter. There's a drain pug at the bottom of the tank.
2.5" exhaust system - Again, homemade. Mild steel with VHT paint, including a single 'Hedman' turbo muffler.
Pm me if interested, pics on request
« Last Edit: May 30, 2010, 03:24:48 pm by dubbeh » Logged
dubbeh
Offline Offline
« Reply #1 on: March 10, 2010, 01:04:23 pm »
will even chuck in a free engineless H-reg polo ready for transplant ?
Traders
Offline Offline
« Reply #2 on: March 10, 2010, 05:22:34 pm »
Whereabouts are you?
dubbeh
Offline Offline
« Reply #3 on: March 12, 2010, 11:00:00 am »
South Wales, close enough to Swansea, j42 m4
dubbeh
Offline Offline
« Reply #4 on: March 15, 2010, 06:08:06 pm »
bttt
g40chris
Offline Offline
« Reply #5 on: March 16, 2010, 01:15:07 am »
seen this setup, looks good and at a fair price imo
nap51dcrow
Offline Offline
« Reply #6 on: April 01, 2010, 04:55:53 pm »
how much would you want for the oil pan shipped to ip28 7ja?
dubbeh
Offline Offline
« Reply #7 on: May 30, 2010, 02:22:36 am »
few bits left
cheddarcheese
Offline Offline
i like boobs!
WWW
« Reply #8 on: May 31, 2010, 04:02:11 pm »
i cant see any prices?
Offline Offline
« Reply #9 on: May 31, 2010, 07:59:22 pm »
What bits are left and pricey would be nice to see mate
dubbeh
Offline Offline
« Reply #10 on: June 02, 2010, 11:52:39 am »
will get a pricelist up asap
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.16 | SMF © 2011, Simple Machines Valid XHTML 1.0! Valid CSS!
