No such thing as a K03s either...
well there is but it's just a k03 with a slightly stronger acuator spring in it as you know yoof. the same turbine and compressor as a normal k03 and since you need to put an adjustable actuator on a turbo g40 for it to work properly, no different at all.
in order to be safe you need to have a decent ecu remap to suit the higher boost and a higher rated map sensor. you can't fit the map sensor without a remap to suit.
